Frankhere1's avatar
Frankhere1
Configuration file NETGEAR
Folks, I have done this before  - back up my router's config file (.cfg)  for later use and 'just in case' conditions. I have not been able to back up  the 1.0.4.12  firmware as I replaced it with ...
  • Frankhere1's avatar
    Frankhere1
    May 27, 2018
    UPDATE:
    After playing around I found that I COULD Save the file if I right-clicked on the mouse , then hit save I did deposit the file into my 'DOWNLOAD'  folder.
    It just does not ( did not, would not) cooperate with me to let ME pick the folder to deposit the file.... ( jheesh!)
    Thanks for your help
    I  am not confused... I want to back up my existing config of the router...
    I have done this before.  Yet when I go to SAVE the file it does not allow me to do this.
    1. Save a copy of the current settings:   I  hit the backup icon
    2.  I now see a screen that says ' You have chosen to open:
         NETGEAR_Nighthawk X6 R8000.cfg
      Yet I click on  SAVE FILE   to save a copy
    3. I also hit BROWSE to select where I  want to put this file    BUT:
    4.  It thinks I  am looing for a file to open  -  once I  browse it only gives me the option
    to OPEN  or CANCEL , but not to SAVE.
    I have tried this several times and get the same result ( as expected)...
    As of today  I cannot SAVE a cfg
    thanks
