Frankhere1
May 26, 2018Aspirant
Configuration file NETGEAR
Folks, I have done this before - back up my router's config file (.cfg) for later use and 'just in case' conditions.
I have not been able to back up the 1.0.4.12 firmware as I replaced it with ...
- May 27, 2018
UPDATE:
After playing around I found that I COULD Save the file if I right-clicked on the mouse , then hit save I did deposit the file into my 'DOWNLOAD' folder.
It just does not ( did not, would not) cooperate with me to let ME pick the folder to deposit the file.... ( jheesh!)
Thanks for your help
I am not confused... I want to back up my existing config of the router...
I have done this before. Yet when I go to SAVE the file it does not allow me to do this.
1. Save a copy of the current settings: I hit the backup icon
2. I now see a screen that says ' You have chosen to open:
NETGEAR_Nighthawk X6 R8000.cfg
Yet I click on SAVE FILE to save a copy
3. I also hit BROWSE to select where I want to put this file BUT:
4. It thinks I am looing for a file to open - once I browse it only gives me the optionto OPEN or CANCEL , but not to SAVE.
I have tried this several times and get the same result ( as expected)...
As of today I cannot SAVE a cfg
thanks
IrvSp
May 26, 2018Master
Works FINE for me. I'm using FireFox and it is set to send all my 'downloads' to a specific folder. I backed up .12 before, and now .18 and it is designated as a (1) after the name.
K:\Inet DL>dir netg*
Volume in drive K is Disk_K
Volume Serial Number is 0F0B-10C0
Directory of K:\Inet DL
05/26/2018 07:38 PM 65,656 NETGEAR_Nighthawk X6 R8000(1).cfg
03/31/2018 09:48 AM 65,656 NETGEAR_Nighthawk X6 R8000.cfg
2 File(s) 131,312 bytes
See the dates they were done?
Suspect something more to do with your Browser? Cache might need to be cleared or try another one?
- Frankhere1May 27, 2018Aspirant
UPDATE:
After playing around I found that I COULD Save the file if I reight-clicked on the mouse , then hit save
Yes, I too am using Firefox .
I also am on Windows 10.
JUst a note - I have issues with Chrome trying to do the same (* fyi only, and not looking to increase the complexity)
ALso checked to see if I have the Latest Chrome and I am up to date - something I puruse regularly.
