Frankhere1
May 26, 2018Aspirant
Configuration file NETGEAR
Folks, I have done this before - back up my router's config file (.cfg) for later use and 'just in case' conditions.
I have not been able to back up the 1.0.4.12 firmware as I replaced it with ...
- May 27, 2018
UPDATE:
After playing around I found that I COULD Save the file if I right-clicked on the mouse , then hit save I did deposit the file into my 'DOWNLOAD' folder.
It just does not ( did not, would not) cooperate with me to let ME pick the folder to deposit the file.... ( jheesh!)
Thanks for your help
I am not confused... I want to back up my existing config of the router...
I have done this before. Yet when I go to SAVE the file it does not allow me to do this.
1. Save a copy of the current settings: I hit the backup icon
2. I now see a screen that says ' You have chosen to open:
NETGEAR_Nighthawk X6 R8000.cfg
Yet I click on SAVE FILE to save a copy
3. I also hit BROWSE to select where I want to put this file BUT:
4. It thinks I am looing for a file to open - once I browse it only gives me the optionto OPEN or CANCEL , but not to SAVE.
I have tried this several times and get the same result ( as expected)...
As of today I cannot SAVE a cfg
thanks
IrvSp
May 26, 2018Master
I re-read your messsage. Are you getting confused between 'backup' and 'restore'?
See the JPG on the right for what I see on that tab and circled the BACKUP which will take the EXISTING settings in the Router and write it to disk. Restore will do the opposite, take a saved BACKUP file and load it into the router (not wise to do after upgrading).
Just wanted to make sure we both understood what you posted.
Frankhere1
May 27, 2018Aspirant
UPDATE:
thanks
