Frankhere1
May 26, 2018Aspirant
Configuration file NETGEAR
Folks, I have done this before - back up my router's config file (.cfg) for later use and 'just in case' conditions.
I have not been able to back up the 1.0.4.12 firmware as I replaced it with ...
- May 27, 2018
UPDATE:
After playing around I found that I COULD Save the file if I right-clicked on the mouse , then hit save I did deposit the file into my 'DOWNLOAD' folder.
It just does not ( did not, would not) cooperate with me to let ME pick the folder to deposit the file.... ( jheesh!)
Thanks for your help
I am not confused... I want to back up my existing config of the router...
I have done this before. Yet when I go to SAVE the file it does not allow me to do this.
1. Save a copy of the current settings: I hit the backup icon
2. I now see a screen that says ' You have chosen to open:
NETGEAR_Nighthawk X6 R8000.cfg
Yet I click on SAVE FILE to save a copy
3. I also hit BROWSE to select where I want to put this file BUT:
4. It thinks I am looing for a file to open - once I browse it only gives me the optionto OPEN or CANCEL , but not to SAVE.
I have tried this several times and get the same result ( as expected)...
As of today I cannot SAVE a cfg
thanks
IrvSp
May 26, 2018Master
Works FINE for me. I'm using FireFox and it is set to send all my 'downloads' to a specific folder. I backed up .12 before, and now .18 and it is designated as a (1) after the name.
K:\Inet DL>dir netg*
Volume in drive K is Disk_K
Volume Serial Number is 0F0B-10C0
Directory of K:\Inet DL
05/26/2018 07:38 PM 65,656 NETGEAR_Nighthawk X6 R8000(1).cfg
03/31/2018 09:48 AM 65,656 NETGEAR_Nighthawk X6 R8000.cfg
2 File(s) 131,312 bytes
See the dates they were done?
Suspect something more to do with your Browser? Cache might need to be cleared or try another one?
Frankhere1
May 27, 2018Aspirant
UPDATE:
After playing around I found that I COULD Save the file if I reight-clicked on the mouse , then hit save
Yes, I too am using Firefox .
I also am on Windows 10.
JUst a note - I have issues with Chrome trying to do the same (* fyi only, and not looking to increase the complexity)
ALso checked to see if I have the Latest Chrome and I am up to date - something I puruse regularly.
