Wingchun's avatar
Wingchun
Configure a router with DD-WRT as a repeater
Have a CAX80 in one house and C7000 in another. Could you tell me if Netgear
modem/router combos will work with a  Netgear DD-WRT router. I want to extend my wifi range with a DD-WRT router as a repeater. Could you provide some Netgear routers that are available if it does work.
  • > [...] Could you tell me if Netgear modem/router combos will work with
    > a Netgear DD-WRT router. [...]
       Treating that as a question, I'd say that it'd be a good question for
    a DD-WRT forum.  (Where "Netgear DD-WRT router" might not be considered
    a very detailed description of either the hardware of the firmware.)
       I doubt that these "Netgear modem/router combos" would care what you
    use as an accessory, if that accessory works with any similarly capable
    router.
