_JR
Nov 03, 2021Aspirant
Configuring Modem Nighthawk X4S AC2600 Smart WiFi Router Model RC8700
I need to reconfigure the router.
I reset the router. (using the reset switch & paperclip)
I can login with name and password.
Followed by serial number.
Now I'm being asked (Router Password Recovery ?) questions about 1) my birth city and 2) my father's name
A reset should reset all, none hardware based, information.
I should be being given the opportunity to establish the answers to the silly questions.
How do I get to the configuration settings for this router?
I was able to figure out how to get to the config settings and am now a happy camper.
Thanks everyone!!
when you reset, push and hold reset for 7-15 seconds while its fully powered on.
then the defaul info is:
login: admin
password: password
all lower case
Is this the C7800 modem or R7800 router?
- _JRAspirant
Thanks everyone!!
Good to hear.
Please mark your thread as solved so others will know.
Enjoy.
