Herbert323
Mar 24, 2017Aspirant
Confused about setting up Port Aggregation
Hi, I just got a new S8000 switch that I wish to connect to my R9000 and use Port Aggregation. I am a bit confused though. Maybe someone can help. My goal: 1. Connect my switch to my router to ...
- Apr 06, 2017I actually figured out what was going on with mine. Once I found and installed the beta firmware, the static lag option showed up. I changed that setting and then connected and everything seems to be running fine and port aggregation says that it's active.
cdominguez2007
Apr 05, 2017Aspirant
I'm also trying to setup link aggregation and I can't get it to work. I followed every procedure in that article, until I get to step 5 to set up LAG on my X10 router. It said to click "Enable (Static LAG)" The only option I have on my screen is "Enable (LACP- IEEE 802.3ad)". Even when I enable that and connect the wires, the port aggregation never says active, but I no longer have the network loops that were shutting me down. I'm at a bit of a loss currently.
- JamesGLApr 06, 2017NETGEAR Employee Retired
Hi cdominguez2007,
Try to check as well this KB.
