Herbert323
Mar 24, 2017Aspirant
Confused about setting up Port Aggregation
Hi, I just got a new S8000 switch that I wish to connect to my R9000 and use Port Aggregation. I am a bit confused though. Maybe someone can help. My goal: 1. Connect my switch to my router to ...
- Apr 06, 2017I actually figured out what was going on with mine. Once I found and installed the beta firmware, the static lag option showed up. I changed that setting and then connected and everything seems to be running fine and port aggregation says that it's active.
cdominguez2007
Apr 06, 2017Aspirant
