hom
Oct 03, 2015Aspirant
Connect Linksys RE4100W range extender to Netgear R7500 router
I just bought a Netgear R7500 router, how do I connect my existing Lindsys RE4100W range extender to it? Thank you.
There’s nothing to be done at the R7500, except perhaps I you have something set up like the Wireless Access List. Otherwise all the setup actions are at the RE4100W;
- Babylon5NETGEAR Employee Retired
- homAspirant
Hi, Andy,
Thanks for the answer.
hom
- homAspirant
One more question, please.
Can now able to connect the Linksys RE4100W range extender to the NETGEAR R7500 router whic is dual band. However the extender can only locate (therefore connect) to the router's 5GHz, but cannot locate its 2.4GHz. Please help explain. Thank you.
