hom
Oct 03, 2015Aspirant
Connect Linksys RE4100W range extender to Netgear R7500 router
I just bought a Netgear R7500 router, how do I connect my existing Lindsys RE4100W range extender to it? Thank you.
- Oct 03, 2015
There’s nothing to be done at the R7500, except perhaps I you have something set up like the Wireless Access List. Otherwise all the setup actions are at the RE4100W;
hom
Oct 08, 2015Aspirant
Btw., both 2.4GHz & 5GHz shown up in the same range extender when I used a Linksys router previously (i.e. before it is replaced by the current NETGEAR router)..
Babylon5
Oct 08, 2015NETGEAR Employee Retired
It’s difficult for me to find any information on the RE4100W, I guess you have a manual? You need to check in the manual for any connection configuration options. I don't know enough about the RE4100W to be able to offer useful advice. have you tried the Linksys forums?
- homOct 08, 2015Aspirant
Thanks for your prompt response.
I'll put my question in the Linksys forum to see if anyone can hlep. Cheers.
