hom
Oct 03, 2015Aspirant
Connect Linksys RE4100W range extender to Netgear R7500 router
I just bought a Netgear R7500 router, how do I connect my existing Lindsys RE4100W range extender to it? Thank you.
- Oct 03, 2015
There’s nothing to be done at the R7500, except perhaps I you have something set up like the Wireless Access List. Otherwise all the setup actions are at the RE4100W;
Babylon5
Oct 08, 2015NETGEAR Employee Retired
It’s difficult for me to find any information on the RE4100W, I guess you have a manual? You need to check in the manual for any connection configuration options. I don't know enough about the RE4100W to be able to offer useful advice. have you tried the Linksys forums?
hom
Oct 08, 2015Aspirant
Thanks for your prompt response.
I'll put my question in the Linksys forum to see if anyone can hlep. Cheers.
