slegere
Jun 20, 2017Aspirant
Connect to existing WiFi network with NO ethernet connection in apartment
Live in retirement community with building wide WiFi. NO ethernet connections in apartment. How do I connect this router to the existing WiFi network? Need to use router because need Hearing Impai...
- Jun 22, 2017
Hi slegere,
The router does not have extender capabilities. You may need to purchase a wireless extender.
JamesGL
Jun 21, 2017NETGEAR Employee Retired
Hi slegere,
Does your phone has ethernet port? You can configure the router to wireless bridge. Check the link below.
https://kb.netgear.com/24105/What-is-bridge-mode-and-how-do-I-set-it-up-on-my-Nighthawk-router
slegere
Jul 15, 2017Aspirant
The phone does have ethernet port. How would I fine the building's speed (2.4 or 5.0)? Im not very network knowledgeable. Can I get other information on existing router using ipconfig?
- William10aJul 15, 2017Master
slegere wrote:The phone does have ethernet port. How would I fine the building's speed (2.4 or 5.0)? Im not very network knowledgeable. Can I get other information on existing router using ipconfig?
If the phone has a ethernet port could be a 10/100mb or a 1gb connection that is able to handle via a wired line cable to a wireless repeater may be able to adapt the lan cable of the phone into a wifi signal for you.
- slegereJul 15, 2017Aspirant
William you showed that the CaptionCall Phone does have a LAN port. Im not a network configuration person. If the apartment does not have a LAN connection on a wall, but only WIFI configured for the building, so no modem, how would I connect this router to the WIFI network in the building. All manuals I've looked at show connecting the router to the modem. Well no modem. The building is WIFI throughout. And the maintenance person has no clue.
Do I connect a laptop/desktop to the WIFI network and then the router to the laptop/desktop to cofigure it as a bridge? Then would I leave the router connected to the laptop/desktop or can I disconnect it and then have the phone connect to the router and still get the Internet access I need on the phone?
If this is not the place to answer these questions, please direct me to the correct place.
- JamesGLJul 16, 2017NETGEAR Employee Retired
Hi slegere,
If you only have WiFi as the main connection of your network, you can setup the router as bridge mode. But bridge will only provide wired connection and does not have wireless capabilities.
