corvairbob's avatar
Mar 10, 2021
connecting 2 units together
i have the c7000 combo unit and i just got the linksys ea7500 router. what i would like to do is put my camera system on the linksys unit to try to get it a bit harder for hackers to get to and then to my system. on some of the camera forums they are saying to make the home network more secure to put the cameras on a seperate router.
anyway at this time just for testing i have both the c7000 and the ea7500 powered on and i have the ea7500 connected to the c7000 using the internet port on the linksys and port 4 on the c7000. i tried using one of the regular ports on the linksys but then i can't see the linksys or connect to it. that may have been because it kept telling me to reset it.
at this time i can see both units and have my pc lan connected and the linksys wifi connected. yea don't need to but i can do anything with the linksys unless i at least connect with the wifi.
so my question is how can i make the cameras connect to the linksys and still see them when i'm out of my home at stores or such? and will i have the added security doing this? if not i can just store the linksys and in the event the c7000 fails i have a spare.
i did watch some youtubes and the way they say to connect them like bridging is not working and conecting then port to port did not work. i had to use the yellow port on the linksys and port 4 onthe c7000 because that one was free.
thanks bp.
  • > [...] how can i make the cameras connect to the linksys and still see
    > them when i'm out of my home at stores or such? [...]
       Didn't we have this discussion in 2018?
          https://community.netgear.com/t5/x/x/m-p/1651330
    Does the phrase "wireless access point" ring a bell?
    > [...] on some of the camera forums they are saying [...]
       Thanks for the helpful links.  Are "they" also saying how to make it
    all work with multiple routers?
       A simple scheme would be to configure "the linksys ea7500 router" as
    a WAP.  One LAN subnet, everyone talks to everyone else, port forwarding
    on the C7000 (modem_router) works as before, and so on.
    > [...] i tried using one of the regular ports on the linksys [...]
       Define "regular port"?  What's an _irregular_ port?  What does
    Linksys call them?
       That's one step toward configuring the EA7500 as a WAP, but I'd guess
    that there's a better way.  One of us might need to consult the EA7500
    documentation to see how to do it correctly.  (I vote for you.)
    > [...] will i have the added security doing this? [...]
       No.
    > [...] if not i can just store the linksys and in the event the c7000
    > fails i have a spare. [...]
       "a spare" _what_?  A C7000 is a cable-TV modem+router.  An EA7500 is
    a router.  See the difference?
    > i did watch some youtubes [...]
       Sincere thanks for not including the links to those.
    > [...] the way they say to connect them like bridging is not working
    > and conecting then port to port did not work. [...]
       Not having wasted my time watching those movies, and having no idea
    what you did, or what kind of "not working" you might have experienced,
    it's tough to comment productively on that.  But how, exactly, would you
    connect any of these devices to each other which would not qualify as
    "port to port"?  To what do you connect anything which is not an
    Ethernet port?
    • corvairbob's avatar
      corvairbob
      Tutor
      thanks i have the ethernet cables connected as that youtube shows now. the only thing i did not do was connect it in that bridge mode. when i was setting it up all those pages did not show up when i was installing it, it kept telling me to press the reset button and wait. so i waited like hours. i had to keep the pc connected via that cable the whole time and i see that was how to do that.
      at this time i have it set so i see both routers  on my phone. and i can connect to either one out in the back yard at the same strenght on my phone but they are about 4' apart at this time down stairs. also if i connect thru wifi onmy pc i can get into the settings on the linksys router. i expect when i change that to bridge mode i will not be able to get into the linksys settings anymore unless i reset it.
      so tell me this if you can if i put it into bridge mode will my stregnth be more because the ls will be higher in the air?
      or will it be so all i see is the netgear router?
      or will i still see both and have about teh same range no matter what unit i connect to?
      so the way it is set now will i gain anything?
      thanks.
      • antinode's avatar
        antinode
        Guru
        > [...] i have the ethernet cables connected as that youtube shows now.
           _Which_ "that youtube"?  And that is how, exactly?  And how does that
        compare with what the product documentation says?
        > [...] the only thing i did not do was connect it in that bridge mode.
           _Which_ "it" is that?  What, exactly, does "that bridge mode" mean to
        you?  "Bridge mode" is a widely misused/misunderstood term.  Does
        "bridge mode" mean to you what it does to Netgear or what it does to
        Linksys?
              https://www.linksys.com/us/support-article?articleNum=247436
           Note "Bridge Mode" versus "Wireless Bridge".  Obviously different,
        but both "Bridge" modes.  Netgear's terminology is less ambiguous.
        > [...] if i connect thru wifi onmy pc i can get into the settings on
        > the linksys router. [...]
           _How_, exactly can you do that?
        > at this time i have it set so i see both routers on my phone. [...]
           "see"?  Are you talking about their wireless SSIDs, or what?
        > [...] i expect when i change that to bridge mode i will not be able
           Why not?  If you know its (LAN) IP address, then I'd expect
        specifying that in a web browser to work.
        > [...] if i put it into bridge mode will my stregnth be more because
           Huh?  "the ls"?  Does that mean the EA7500?
           Tell me this, if you can: How would changing the operating mode of
        the EA7500 change its elevation?
           You seem to assume that someone who reads this scrambled mess would
        have some idea of how "it is set now", whatever "it" is.  I sure
        wouldn't bet on it.
           If you have two routers, and both are configured as full-function
        routers, then I'd expect problems with access from the outside world to
        devices which are connected to the inner router.  Which is why you keep
        getting suggestions to configure the EA7500 as a WAP (which Linksys
        calls "Bridge Mode").
           Have you looked at the IP addresses of your devices when they're
        connected to the C7000 versus when they're connected to the EA7500?
      corvairbob
      Tutor
      ok plemans i did what this said
      try setting up the linksys as an access point.
      https://www.youtube.com/watch?v=OaUIYpf0S00
       and now i do not see the linksys router. that could be normal i do see the linksys in the internet access icon an i can connect to the 2.4 and the 5 ghz bands. but setting next to the router the 2.4 band is way slower for the speed test. so maybe this router is not as fast as the c7000 is. using the wifi connections
      linksys 2.4  20 mbps
      linksys 5  30 bps
      netgear 2.4  23 mbps
      netgear 5  230 mbps
      so is that now a normal thing to lose the linksys router when i open a tab and enter 192.168.1.1  ? because one of the youtubes said not to use the yellow port but the youtube you sent me to showed using the yellow port   also because i do not yet have a place for the linksys router can i turn it off and not lose any settings for the next time i turn it back on?  thanks
      • plemans's avatar
        You'd be best to ask on the linksys forum what its expectations are in bridge mode.
        if you watched the video, it literally goes over the fact that you're changing the IP address for the linksys. You'd then use that address to access it.
