PoBear
Mar 16, 2021Aspirant
Connecting R7000 to TP-Link 9970
I'm new to this so please be gentle. I have a TP-Link TD-9970 that I have set into bridged mode, I've connected my R7000 to it with an ethernet cable connected to one of the LAN ports on the 9970...
PoBear
Mar 17, 2021Aspirant
> TD-W9970?
Sorry, yes it's W9970
> How, exactly?
The 9970 has an option to put it into bridged mode. See
How can I set up my TP-Link modem router as a pure modem? (tp-link.com)
The example is for VDSL but it is supposed to work for ADSL as well.
When I put the w9970 inro Bridge mode the gui said it had connected successfully.
> Is your goal to use the TD-W9970 as a DSL modem only
Yes, I want to use it as a modem for the r7000
> Where, exactly, is this "an orange light"?
It's the WAN light, second from the left
> That doesn't sound to me like "bridged mode".
It's the LAN IP Address that I can access the 9970's gui
> When configured as a router, an R7000 has two IP addresses
It's the LAN address for the r7000 that I set, the WAN IP is allocated by PlusNet if I understand it correctly. My old modem/router (not the w9970) used 254 and I don't want to have to setup every device on my network again.
> With my weak psychic powers
I've run the setup through the Blackhawk app. the automatic setup in the r7000 gui and I have entered my Plusnet credentials into the Internet setting in the r7000 gui.
I'm using instructions from several posts that I have found on the Plusnet site about connecting the two but they weren't detailed and appeared to work for the person first time.
antinode
Mar 17, 2021Guru
> successfully.
What, exactly, was "successful"? The DSL physical link?
What happens if you connect a computer directly to the
TD-W9970-as-modem?
> It's the LAN address for the r7000 that I set, [...]
Ok. (Why?)
> [...] the WAN IP is allocated by PlusNet if I understand it correctly.
It would be, if the R7000 ever connected to PlusNet. What is it now?
ADVANCED > ADVANCED Home : Internet Port : Internet IP Address? (I'd
expect all-zeros until the ISP connection was established.)
> [...] My old modem/router (not the w9970) used 254 and I don't want to
Why would you need to do that? I'd expect client devices which use
DHCP to fall into line with the router, wherever it is.
In principle, you should be able to set the R7000 LAN IP address to
almost anything, but, if the TD-W9970-as-modem is using "192.168.1.1",
then I wouldn't bet that "192.168.1.X" would be a good choice for the
R7000 LAN. I might set it to something like, say, "192.168.8.1".
If the R7000 LAN is set to "192.168.1.X", then I'd expect trouble
getting to the TD-W9970-as-modem at "192.168.1.1" through the R7000
(because the R7000 would see "192.168.1.1" as being on its LAN, so it
wouldn't try using its WAN/Internet interface to reach that address, and
that's where the TD-W9970-as-modem is).
Until I got something to work properly, I'd minimize the
customizations on this stuff. (".254", for example.) _After_ I got
something to work properly, I might start trying to break it by changing
stuff.
> I'm using instructions from several posts that I have found [...]
It's nice that _you_ found them, but that doesn't help me much.
Are there any special characters in your PPP credentials? I don't
know about the R7000, but some Netgear routers have had trouble with
them, and bad credentials could stop your PPPoE connection from working.
https://community.netgear.com/t5/x/x/m-p/1354547
Which version firmware is on the R7000?
- PoBearMar 21, 2021Aspirant
Sorry for the delay in getting back, the W9970 did not like my original cabling and I had to move it next to the telephone socket.
Any, after having a clean connection to Plusnet for 24 hours I tried reconfiguring everything.
I now understand why I had issues with the W9970 and was able to successfully put it into bridged mode with a solid connection to Plusnet.
I then tried connection the R7000, first I tried a factory reset and using the Nighthawk app to set it up, no success. Then I tried using the setup wizard in the gui and then a manual setup, each time no internet connection.
The R7000 is running V1.0.9.88_10.2.88, I've checked and it is the latest version.
I have managed to set the R7000 as an AP, so I know all the cabling is working but it means I have lost most of the functionality I bought it for.
- antinodeMar 21, 2021Guru
> [...] and then a manual setup, each time no internet connection.
None of that says what you did. See "As usual, [...]", above. Feel
free to answer any of the other pending questions.> [...] V1.0.9.88_10.2.88, I've checked and it is the latest version.
"checked" _how_, exactly?
OK. The Night hawk app leads you thru setting up your router; connecting to it via wifi, setting a new password then it checks whether you have an internet connection at which point it stopped.
The wizard is launched from the R700 gui, the first thing it checks is whether you have an internet connection.
Manually I added the credentials for my ISP but I still did not have an internet connection.
It's displayed in the gui top right.
