dptraynor's avatar
Jan 04, 2021
Constant Disconnects - Netgear R6400 v2 - Router Mode - .71, .75, .80
Hello!
I have experienced an issue with my Netgear R6400 (v2) in Router Mode. It works on reboot for a few minutes. Then it disconnects and the Nighthawk app reports it as offline if I check there. I have tested this on three different firmwares (10.0.71, 10.0.75, 10.0.80) and the issue persists regardless. I live in an apartment building so there are other routers present throughout the building.
Is there something I don't know about with the set-up that may alleviate this? Or is it most likely just a faulty hardware?
    • dptraynor's avatar
      dptraynor
      Tutor
      It does not. Once I notice the disconnect, I perform a reboot, and it works again for a short time.
      • plemans's avatar
        What modem/gateway is the router connected to?
