Steve_Dude
Sep 07, 2015Aspirant
Correct settings to use Smart Connect and Load Balancing?
Hi guys I have a question, the answer to which I have not been able to find explicitly, therefore I hope for a quick OK / not OK from you: I would like to use the triband technologie the R800...
- Sep 07, 2015
Balancing means between two radios. 2,4GHz band has only one radio vs, 5 GHz band's two radios.
netwrks
Sep 07, 2015Master
R8000 manual - Smart Connect. Page 72. You should always distinguish between 2.4 and 5ghz in SSID labels.
- Steve_DudeSep 08, 2015Aspirant
Thank you,then I did everything right!
