Elle01's avatar
Elle01
Tutor
Jan 27, 2022
D6400 Error 1 Firmware update fails. Manual .chk won't 'open' on a MacBook.
Hi, I'm behind by several versions of firmware because each time I attempt to update it fails. I've seen other questions along a similar line being rectified by updating with a version inbetween first. Great idea - except - my macbook won't open the .chk file contained in the zipped file to enable me to do this.
How do I 'open' the .chk file to upload the update to the router? It prompts and asks which 'app' I want to use to 'open' it.
The Netgear Maual says ...
8. " Locate and select the firmware file on your computer: Click the Browse button. Navigate to the firmware file.
The file ends in .chk. An example of a firmware file name is D6400-V1.0.0.22_1.0.22.chkSelect the firmware file. Click the Upload button."
All very wonderful, and each step works, until the last - there is no 'upload' button - only the prompt from macbook to 'choose an app to open the file in'!?
I've tried updating using the Netgear Genie - doesn't work. I've tried it in the advanced settings on the routerlogin.net page - doesn't work - Unknown Error 1.
I read one of Netgear's articles about manual updating. The first instruction was to connect laptop via an ethernet cable - I have a macbook - there is no RJ45 port and I don't have a working USB adaptor.
Is there a way to update the firmware without a hardwire using wireless only? A) I'm concerned about the security issues. B) My printer is deciding it needs to be turned off and on between every. single. print job otherwise the laptop gets stuck in a neverending cycle of 'searching for printer'. I'm guessing this may be something to do with the firmware on the router not being up to date and possiblly not playing nice with the WIFI on the printer??? Or am I guessing wrong? Either way - firmware needs updating.
Any suggestions ?  (I rely very heavily on the internet connection for multiple reasons and am more than a tad concerned about bricking it!)
  • You can do it over wifi.
    We recommend over wired because its a solid connection without interference.
    But wifi does work.
