EFillF's avatar
EFillF
DD-WRT and Warranties.
Will installing DD-WRT on my router void the warranty I have on my router?
  • TheEther's avatar
    Nov 27, 2015
    If you read the terms of the warranty, it does say that Repair or modification of the product by anyone other than NETGEAR or a NETGEAR approved agent will void this warranty.  It doesn't specify whether that means physical or firmware modification, but I could envision that Netgear could claim that installing DD-WRT voids the warranty.
    If you have problems, you could always re-install stock firmware.  If you brick the router while DD-WRT is installed, then you may be out of luck.  It's up to you to determine if you can afford that risk.
