Danser
Dec 04, 2018Aspirant
DD-WRT firmware
Can someone tell me how to get my router setup with DD-WRT?
Thank you
- Dec 06, 2018
Michael I'm sorry I came here to ask about something I should have gone to the other sites to ask. It's that I had just gotten the R9000 and wanted to flash it. After reading at more than one site I could brick the router I decided to forget it. Not worth it.
Thanks and I'm gone for this topic.
michaelkenward
Dec 05, 2018Guru - Experienced User
There are a few people here who use these alternatives to the official firmware, but your best bet is to try the places where they cover different firmware.
You aren't likely to get much help on an official Netgear forum. It does not support third party firmware.
- DanserDec 05, 2018Aspirant
Thanks,
Micheal. I really don't know what, or why my VPN needs it anyway.
- michaelkenwardDec 05, 2018Guru - Experienced User
Does that mean that your question is really about the VPN?
If so, you would do better to ask about that.
Tell people what it is and you might get useful advice.
No! I don't like the way you came back to me, or is it how you treat everyone asking questions that are merely asking because they don't know the answer. Don't assume. What I meant is was what I said in the first post. It had nothing to do with a VPN other than the VPN I signed up with. They need a DD-WRT router via the OpenVPN GUI client in order to use their VPN. Take that as useful advice. Man... Geezz
