Danser
Dec 05, 2018Aspirant
DD-WRT firmware
Can someone tell me how to get my router setup with DD-WRT?
Thank you
- Dec 07, 2018
Michael I'm sorry I came here to ask about something I should have gone to the other sites to ask. It's that I had just gotten the R9000 and wanted to flash it. After reading at more than one site I could brick the router I decided to forget it. Not worth it.
Thanks and I'm gone for this topic.
Danser
Thanks,
Micheal. I really don't know what, or why my VPN needs it anyway.
michaelkenward
Dec 05, 2018Guru - Experienced User
Does that mean that your question is really about the VPN?
If so, you would do better to ask about that.
Tell people what it is and you might get useful advice.
- DanserDec 06, 2018Aspirant
No! I don't like the way you came back to me, or is it how you treat everyone asking questions that are merely asking because they don't know the answer. Don't assume. What I meant is was what I said in the first post. It had nothing to do with a VPN other than the VPN I signed up with. They need a DD-WRT router via the OpenVPN GUI client in order to use their VPN. Take that as useful advice. Man... Geezz
- michaelkenwardDec 06, 2018Guru - Experienced User
Your first message said:
Can someone tell me how to get my router setup with DD-WRT?Then you said:
I really don't know what, or why my VPN needs it anyway.I was just trying to home in on the real problem so that someone can provide the best answer.
If you aren't interested in that, fine.
- myerswDec 06, 2018Master
If you want to install DD-WRT on the r9000 you need to be on the dd-wrt forums with your question. Am sure it is easy, like grabbing a particular file to install. HOWEVER, check to see what it takes to get back to OEM if you want. That may require using the serial interface which means cracking open the router. Have installed on various routers so have that experience.
