kingsc's avatar
kingsc
DHCP Option 82
Does the R7400 router support this option?  I noticed in packet captures that when I send that option, the DHCP service doesn't respond, but does just fine if I don't include it.
  • FURRYe38's avatar
    Might check NGs support page and user manual for this option.
    https://www.netgear.com/support/
    Or with in the routers web page. Maybe seen under Advanced tab/Setup/Internet or under Advanced Tab/Advanced section.
    If you don't see this feature displayed anywhere, may not be supported.
      • kingsc's avatar
        kingsc
        Yeah I didn't see anything about it in the user manual.  Bummer.  I need this option to support an important endpoint identification feature in my management platform.
