Clear_light
Feb 03, 2022Aspirant
Did a factory reset and now netgear wont let me log in via ISP - keeps redirecting to Nighthawk APP
Hi,
I had to do a factory reset and now I'm trying to log back in and set things up -- without using the nighthawk app. But every time I type in Http://192.168.1.1, I am redirected to a page to download the nighthawk app.
I have cleared the cache and browing history. Is there any way around this ?
Thank you,
Model AC-1600 / R6260
Thank you. I did scroll to the bottom and click, but I kept getting redirected to Netgear web pages.
I finally figured it out. I had to disable VPN and brave shield.
How are you getting into the router? Wifi? Wired?
Type in where? A browser? Which one? Tried an alternative?
What modem/gateway sits between the router and the Internet?
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
If you want to read about other experiences with your router, you might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
General WiFi Routers (Non-Nighthawk & Non-Orbi) - NETGEAR Communities
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.- Clear_lightAspirant
Hi,
I put the model number in the body of my post, so I'm not sure why it did not show?
I'm not super tech savvy, so I appreciate your patience as I describe this.
My setup:
1. I have a Netgear Modem (CM500)
2. Netgear router (AC-1600/R6260) connected to modem with ethernet cable
3. Desktop PC is connected with ethernet cable into the router
I opened a browser window and typed https://192.168.1.1 into the search bar
(Brave Browser/Duck Duck Go, but also tried Firefox/Google)
I do have a copy of the manual downloaded onto my computer. This is not the first time I've had issues with this router. :-(
The instructions don't give much more detail than to type in the IP address or use their App.
I have been searching forums...extensively.
Every time I type in the 192....IP address, I get redirected to a web page about the NightHawk asking me to download the app.
I have cleared the cash/cookies/history for both browswers.
I don't want to use the Nighthawk App.
In the past, I was able to simply type in the IP address and access my router. What happened? and How can I fix this?
Many thanks.
On the page it refers you to the app, scroll down to the botton and there's a link that says something like "I don't have or phone" or something like that. Click it and you should be able to use the browser for setup.
