CharLans
Nov 07, 2020Follower
Difficluties Setting Up EX7700 extender
Dear Community,
I am having trouble setting up my EX7700 extender. It had been set up with a different router but I had to recently change to a new one. Doing that, however, has meant that I can't seem to set up the Extender with the new router. The client link LED is a solid white and the WPS led is a solid white but the router link LED is off (will periodically flash red but then go dead). When I try to use the Nighthawk Netgear app to set up the extender with the new router, however, it can't find "NETGEAR_EXT" and thus I cannot update the extender to access the new router. The app/extender says it is having problems connecting to the wifi.
What do I need to do so that the extender, configured to a router and wifi system I no longer use/have, can be configured to my new router/wifi?
Thanks for your assitance in advance!
1 Reply
> router/wifi?Have you considered trying the the obvious?
https://en.wikipedia.org/wiki/RTFM
Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the User Manual. Read. Look for "Factory
Default Settings" and/or Return the Extender to Its Factory Default
Settings". Do that. Then, start at the beginning with your newly
virginized extender. Its User Manual might be helpful with that
operation, too.
