monkey211
Jan 23, 2022Follower
disable charging when tethering
Is there a way to disable charging when I am tethering via the USB c port? I tether to my MacBook pro, but I don't want to charge my mr1100 from my MacBook pro when tethering.
If you want more than the answer from microchip8 you should ask in the place where they talk about the MR1100.
Mobile Routers, Hotspots & Modems
Those things are very different from the standard Netgear routers covered in this section.
- microchip8Master
No
