FURRYe38's avatar
Disable DNS Relay on R9000
Sorry if this question has been asked before. It's been a while since I had been using NG.
I was curious of DNS Relay could be disabled on the R9000 or if NG keeps this feature closed on there products?
Thank you.
  • Netgear does not offer the option to disable it.  You can upvote my request here.
    • FURRYe38's avatar
      Thank you. Voted and left a comment. Hope to see it in the near future if possible.
