sgp9's avatar
sgp9
DL speed at half , hard wired to pc
 My DL speeds are at half speed throught he router. I can connect directly to the pc from the modem and get 235mb dn. I connect through the router I get 95mb dn .?
 This wasn't always the case. I checked speeds a couple months ago and was fine.
 I rolled back firmware to an earlier version , didn't help.
 I turned off Qos ,didn't help
 Any help would be apreciated..
 thnx
  • Changed DNS server on router to 8.8.8.8   8.8.4.4 .. Speeds are back up 230,s dn..
     thnx for the help
  • FURRYe38's avatar
    So what NG router are you referring too?
    • sgp9's avatar
      sgp9
       The router is a Nighthawk r7000
        The firmware is V1.0.11.100_10.2.100
        And yes, I did a factory reset..
       The Modem is an Arris TM1602A
      • FURRYe38's avatar
        Have you powered OFF the ISP modem and Router for 1 minute or longer then power back ON the modem then router?
        Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
