BigWaveDave372's avatar
Mar 09, 2021
DNS Issue - Again
"The only explanation I can think of is that the connection from the modem refreshed which the router's settings did communicate with the modem. After you refresh or reset the router of factory default it works."
What is going on with Netgear and DNS?! The above quote is from 11/8/16. Netgear seems to be unwilling or unable to fix the issue.
1 Reply
