beautifulday
Jul 05, 2017Aspirant
Do i need to update R7900 from costco
Greetings! I was just told by Cox Cable that I needed to reset my r7900? that I had a glitch in it? do I also need to update it? I appreciate your time and expertise.
- Jul 19, 2017
Hi beautifulday,
Check with the printer manufacturer if you need to update the software or driver of the printer.
JamesGL
Jul 11, 2017NETGEAR Employee Retired
Hi beautifulday,
May I know what issue or problem you encountered with the router?
- JamesGLJul 16, 2017NETGEAR Employee Retired
Hi beautifulday,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
- JamesGLJul 19, 2017NETGEAR Employee Retired
Hi beautifulday,
- beautifuldayJul 17, 2017Aspirant
Good evening!
I was having trouble with the printer disconnecting from the router. When I called my cable company, they suggested updating the software.
Do I need to? Since I wrote that, I haven't had any problems. Thank you for your time and assistance.
Please just email me directly. [email protected]
Enjoy your evening!
Marianne
