beautifulday
Jul 05, 2017Aspirant
Do i need to update R7900 from costco
Greetings! I was just told by Cox Cable that I needed to reset my r7900? that I had a glitch in it? do I also need to update it? I appreciate your time and expertise.
- Jul 19, 2017
Hi beautifulday,
Check with the printer manufacturer if you need to update the software or driver of the printer.
