Markw6mcs
Sep 11, 2023Aspirant
Do I need to upgrade my AC1750 (R6700)? Having to reboot often.
I have an older (4 years old) Nighthawk AC 1750 that has worked well until I added some hardware to the system in June. Since then I have had certain devices drop off the system and forcing a reboot....
- Sep 16, 2023
đ
Markw6mcs
The house it self is a bit over 2000 square feet and is single story.
When ADT was out to check out what I needed, they did some kind of signal test to see if the 6700 could get out to the garage door where one of the security cameras would live and the signal was just on the edge of being strong enough, hence the purchase of the the Nest router and access point.
I am no techie and while I do not know how it was tested, I trust the ADT technician that did the test as I have used him before. I know it has something to do with minus decibals or something. He showed me on the app he was using.
Thanks for the help - Mark
Sep 16, 2023Guru - Experienced User
đ
