Tracerr
Dec 01, 2016Aspirant
Docsis 3.1 not available on R8000
So I love my Nighthawk to bits and cannot see having internet without it, bought it a couple of months ago for use on Vodafone NZ's cable network and it server me very well gor 101MB down and 10MB up...
- Dec 12, 2016
If your R8000 is still configured as an Access Point (AP), then try connecting it to the Huawei using a LAN port on the R8000. IOW, leave the WAN port disconnected. You should be able to achieve Gigabit speed this way.
The downside with this workaround is that you may not be able to log into the R8000. You will have to reconnect the WAN port to log in.
Tracerr
mmm cant be my router as it is brand new and the techs installed the new modem this morning along with their router and they just said I should set my internet/wan to auto pickup an address from the modems dhcp pool..I did that and it is not working...but when I plug their router in it works....
Tracerr
I wonder if the netgear has a problem reading the fast data port/internet connection from the modem to the router...I tried it again with no luck the new modem is defnitelly running Docsys 3.1 where the old one was docsys 3.0...on the new router I am getting 942.91Mbps down and 99.74 Mbps up and on the old one I had 101Mb down and 10Mb up
- TheEtherDec 01, 2016Guru
The R8000 has a Gigabit Ethernet port. It should have no problem with respect to link speeds.
