Tracerr
Dec 01, 2016Aspirant
Docsis 3.1 not available on R8000
So I love my Nighthawk to bits and cannot see having internet without it, bought it a couple of months ago for use on Vodafone NZ's cable network and it server me very well gor 101MB down and 10MB up...
- Dec 12, 2016
If your R8000 is still configured as an Access Point (AP), then try connecting it to the Huawei using a LAN port on the R8000. IOW, leave the WAN port disconnected. You should be able to achieve Gigabit speed this way.
The downside with this workaround is that you may not be able to log into the R8000. You will have to reconnect the WAN port to log in.
Tracerr
mmm cant be my router as it is brand new and the techs installed the new modem this morning along with their router and they just said I should set my internet/wan to auto pickup an address from the modems dhcp pool..I did that and it is not working...but when I plug their router in it works....
TheEther
Dec 02, 2016Guru
On the R8000, go to the Internet tab and make sure Get Dynamically from ISP is selected under Internet IP Address.
Connect the R8000 Internet port to the modem. Power cycle the modem. Some modems need to be power cycled when you change routers. Check the Advanced tab on the R8000 and see if Internet port has an IP address.
If it still hasn't acquired an IP address, then try cloning the HG659's WAN port MAC address into the R8000. Enter it where it says Router MAC address in the first picture. Click Apply and reboot the router.
If the router still can't connect to the Internet, then another approach you can try is to connect your HG659 to the modem, then connect your R8000 to the HG659. Enable AP mode on the R8000 at ADVANCED > Advanced Setup > Wireless AP. This will convert the R8000 into an Access Point. Your HG659 will be your main router.
Good luck.
- TracerrDec 02, 2016Aspirant
Thanks TheEther...
Option 1 did not work
Option 2 along with option 1 where I clkone the mac address of the huwai router did not work
Option 2 kind of worked but when I plug my pc directly into my netgear I only see speeds of under 500Mbs where if I plug directly into the Huwai I see speeds of 908Mbps and up....
Hope Netgear comes out with a firmware update of sorts to sort this problem....
- TracerrDec 12, 2016Aspirant
Still cannot get high speed cable to work on my nighthawk,it really is as if the wan/internet port cannit see the high speed cables dhcp server or something....there must be a fix
- TheEtherDec 12, 2016Guru
