phongthuypts's avatar
phongthuypts
Does Netgear have any plan to fix DNS problem in R8000 1.0.4.84?
All updates after 1.0.4.68, including 1.0.4.84, caused DNS problem where the R8000 router spit out DNS related errors.
Older revisions seem to work fine.  The problem is using older revision poses security risk.
Is there a plan for the DNS fix?
PTS
  • FURRYe38's avatar
    Have you enabled IPv6 Auto to see if this helps any on v.84?
    We've brought this up to NG.
    • phongthuypts's avatar
      phongthuypts
      I don't remember seeing IPv6 setting so the answer probably no.
      However, my network is all ipv4 at this point.
