Soapstreet's avatar
Soapstreet
Does readyshare even work on the Nighthawk R7000? USB Drive not detected.
First off. I have at least one usb hard drive that is on the compatibility list.
Windows 10 64bit and newest Netgear R7000 firmware. Cant remember the version. I bought the router about 8-10 months ago and just decided to try out the readyshare and add a NAS.
Ok, so I had 2 different USB 3.0 drives to try out. One was a Western Digital 1TB and the other was the Samsung T1 250GB SSD. I plugged one into the USB 3.0 port on the front and went into windows 10 to enable the file sharing or whatever it's called. Sorry I am at work and can't remember. Once I enabled it I could see my TV's and my R7000 router under "Network" but not the NAS. I went into the router settings under ReadyShare and enabled basic for network and the drive was showing \readyshare\USB_drive with a drive letter of U: showing. When I copy the address and paste it into Windows explorer it will not pull the drive up. I also tried to map the drive but it wasn't detected when I tried. Someone told me I need to share at least one folder for it to show up under "Network" but I don't believe that is correct after testing. When I click "edit" it tells me "No Disk". When I look at the router neither of the 2 usb lights are on. I also tried it in the 2.0 slot. Whats weird is that when I plugged in the usb Samsung SSD the light came on and for whatever reason, I could see the 1TB and the SSD in readyshare on the Netgear UI even without the 1TB plugged in. I clicked edit and shared a random folder on the SSD to see if the guy was right that told me to do it. Then I took the \readyshare address it gave me for the detected SSD and plugged it into windows explorer. NO GO. The PC is basically not detecting the drive that's plugged into the router and sometimes the dang router doesn't even detect it being plugged in. I am beginning to think this is a firmware issue as I am on the newest firmware. Thanks for any input. Hopefully you can understand my frustration.
  • If you have a NAS storage device you should be connecting this by ethernet cable to your router, not usb.  If it is usb only then it is an external hard drive,  not NAS.
    Netgear have a compatibility list for hard drives,  which can be found here
    Basic rules of thumb is if you would need to install drivers on a pc for your hard drive to work it probably won't work with netgear ready share routers
    • Soapstreet's avatar
      Soapstreet
      I understand that it is not a real "NAS" but hoped you would catch my drift. One of my usb hard drives is on the compatible list and the other is not but they both showed up at some point in the Netgear UI.
      • clithes's avatar
        clithes
        Prodigy
        Netgear GUI often recognises the name of the device when looking at attached usb devices, however having read/write access to them is another matter
        For the drive that is on the list, once set up what happens on your pc when your browse to //readyshare in windows explorer ?
        Do you see USB_Storage?
      • JamesGL's avatar
        JamesGL
        NETGEAR Employee Retired
        Hi irwinsg,
        You can use the R7000 list as it has the same list.
  • I just returned an R6400 router because it wasn't compatible with my PNY flash drive. I purchased an R7000 because the Netgear compatibility list said the PNY would work. It doesn't. The drive I want to use for network storage is a PNY Elite Portable SSD 240GB. I get no connectivity at all with this SSD.  I do have some older, smaller thumb drives (2-4GB range) that work, so the USB ports are not dead.
    Has anyone been able to connect an SSD (+/- 250GB) to the R7000 USB Readyshare? What brands/models/sizes really work?
    • RonnieK's avatar
      RonnieK
      I own a Netgear R6250 and decided to upgrade to the R7000. My R6250 readyshare functions flawlessly for the two usb powered drives I own. But the R7000 will not display them. Have gone into the router configuration and "refreshed" multiple times. It displays the drive, but will not pass thru to the workgroup. Looks like a firmware issue. Works fine on the R6350, so I'm returning the R7000. Not trying to lose capabilities that I had before.
