rkruz
Feb 23, 2022Apprentice
Does Router Return "Unavailable" to sender with each "DoS attack" log?
I turned on my PC and immediately got a series of DoS attack log entries. Does each entry in the log mean that the router has returned a message for each log entry that the network is unavailable fo...
- Feb 23, 2022
No. It is blocking the "attacks". It doesn't return anything but sends a DROP in its firewall and logs an entry
NETGEAR's DoS protection is famously know for many, many false positives. Some can even come from your ISP or your own devices on LAN/WiFi. Always look up the IP address it reports to see if it's legitimate or not. If you have problems, disable DoS "protection" clompletely (you're not losing much at all) to relieve the router. If you want to keep it on, at least disable the logging of these "attacks"
PS: I run 4 years without this faulty DoS "protection" and never had any issues
microchip8
Feb 23, 2022Master
- rkruzFeb 23, 2022Apprentice
Understood. Thanks for clarifying.
