rkruz's avatar
rkruz
Apprentice
Feb 23, 2022
Does Router Return "Unavailable" to sender with each "DoS attack" log?
I turned on my PC and immediately got a series of DoS attack log entries. Does each entry in the log mean that the router has returned a message for each log entry that the network is unavailable fo...
  • microchip8's avatar
    Feb 23, 2022
    No. It is blocking the "attacks". It doesn't return anything but sends a DROP in its firewall and logs an entry
    NETGEAR's DoS protection is famously know for many, many false positives. Some can even come from your ISP or your own devices on LAN/WiFi. Always look up the IP address it reports to see if it's legitimate or not. If you have problems, disable DoS "protection" clompletely (you're not losing much at all) to relieve the router. If you want to keep it on, at least disable the logging of these "attacks"
    PS: I run 4 years without this faulty DoS "protection" and never had any issues
