charlesle's avatar
Oct 12, 2015
Does the Nighthawk X8's Power Supply Support 240V (USA Model)?
  • ElaineM's avatar
    ElaineM
    Oct 13, 2015
    This should be working perfectly.
    We have one working in a remote office using 240V.
  • ElaineM's avatar
    ElaineM
    NETGEAR Employee Retired
    Hi charlesle
    Welcome to the community!
    Yes you can. Just make sure that you use the same DC output of 19V, 3.16A.
    • charlesle's avatar
      charlesle
      Tutor
      Thank you ElaineM
      As an U.S. expat working in India, I was planning to get a co-worker to bring the X8 for me next week. I have an India purchased universal power strip (made by Belkin), which uses a Type D (5A) plug as shown here:
      http://www.worldstandards.eu/electricity/plugs-and-sockets/
      I can plug your typical U.S. Type A plug into it and it works fine for all of my gadgets (MBP, work laptop, etc.)
      Can you confirm if things will work properly? I am not sure when the X8 is coming to India, but the reason I'd like to bring one from the U.S. is so I am able to use it in my home when I return to the U.S. without having to hook up a power adapter.
      • ElaineM's avatar
        ElaineM
