ex2hale
Nov 08, 2016Guide
dos attack by ISP?
Hello, I have been having trouble with my nighthawk. Today I had cox come out to fix an issues to me losing internet random for about 20 seconds. The guy took off a filter that is inbetween the mode...
- Nov 29, 2016
So the problem is fixed!! :) I am posting this so if anyone has the same problem they can fix it too. First things first the router and/or the equipment was not the problem. The problem was cox sent out dip**bleep** techs to my house over and over. When calling cox the last time I told them my modems power signals were not looking correct and told them about my modems logs. Ask your ISP for i believe what they call a "Data Tech" this tech actually knew what the **bleep** they were doing and fixed the issues. I had been dealing with this problem for over a year and it took the tech 30 minutes to fix my problem. So in ending this topic after the tons of hours looking on the internet and wasting my time JUST CALL YOUR ISP and have them fix the problem if your logs and symptoms are the same as mine, do not waste your time. Hopefullly this helps someone else out.
these were the errors my modem was giving to look my modems logs i typed 192.168.100.1 in the search bar:
2016-11-15, 20:48:43 Critical (3) Unicast Ranging Received Abort Response - Re-initializing MAC;CM-MAC=40:5d:82:e5:26:a0;CMTS-MAC=00:1e:be:ff:28:b0;CM-QOS=1.1;CM-VER=3.0;
2016-11-15, 20:48:57 Warning (5) Dynamic Range Window violation
ex2hale
Nov 09, 2016Guide
after disabling dos protection i seem to be dropping internet more frequent. i downgrade to V1.0.5.70_1.1.91 and same thing is happening. i dont know what else to do.....
IrvSp
Nov 10, 2016Master
Have you tried a different cable between the modem and router?
Sometimes you can get to the modem and see its log. In my case I can, it is an ISP provided Surfboard SB6141 and if I enter 192.168.100.1 into a browser I can see it. If that works and you can see a LOG tab, check it out for yourself.
Oh, for month I've not seen any attacks (I get logs emailed to me daily) and today I see it happened twice yesterday.
[DoS attack: Smurf] attack packets in last 20 sec from ip [184.88.19.241], Wednesday, Nov 09,2016 17:01:13
[DoS attack: ACK Scan] attack packets in last 20 sec from ip [52.7.238.134], Wednesday, Nov 09,2016 09:02:42
First is Time Warner, which my ISP uses for email (Road Runner). Second is Amazon. I used this site, https://www.ultratools.com/tools/ipWhoisLookupResult to look them up. Neither is a real attack.
- ex2haleNov 10, 2016Guide
i have tried multiple cables and same thing whats weird is my connection is more stable with dos protection on?
- IrvSpNov 10, 2016Master
Leave the DOS Protection on.
Make sure the MTU is 1500 too.
One other 'trick', under ADVANCED TAB --> SETUP --> INTERNET SETUP, under ROUTER MAC ADDRESS, set it to 'USE COMPUTER MAC ADDRESS" which you can just check and then SAVE. This will 'simulate' having the PC connected directly to the Modem. See if that helps.
when i switch the mac address i do not have any internet at all. MTU is at 1500
