elmirain
Nov 26, 2017Aspirant
dose Netgear Nighthawk R8000 suppot Amazon Echo
- Nov 29, 2017
Hi elmirain,
It does support Alexa for Amazon Echo dot.
https://kb.netgear.com/000036881/How-do-I-link-the-NETGEAR-skill-to-my-Alexa-app
JamesGL
Nov 29, 2017NETGEAR Employee Retired
Hi elmirain,
- JamesGLDec 03, 2017NETGEAR Employee Retired
Hi elmirain,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
- elmirainDec 03, 2017AspirantThank You you information made it easy for me to chose the correct router. Thanks for your help
Hi elmirain,
You are welcome.
If your question has been answered we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
