2pfspiff's avatar
Dec 05, 2017
Double Nat issue for Xbox One
Good day all.  I am having a double Nat issue with my Xbox 1.  I have the X6 R8000 going to a comcast 1GB's Router in my basement.  The X6 has the latest firmware update and I just did a reset of the router.  I can not put my Modem/router from Comcast into bridge mode because I will lose my interenet connection for my security system which is also from comcast (X1 quadruple Play so to speak).  I did set the X6 to Open Nat in Netgear Genie.  Is there another work around or do I have to set my modem into Bridge mode.  I did set up a static IP for the Xbox one and have it set up in DMZ mode.
  • > [...] Is there another work around or do I have to set my modem into
    > Bridge mode.
       If all you want is wired/wireless network access far from the main
    modem+router (and there's an Ethernet cable (or equivalent) between the
    two locations), then what you may want is to put the R8000 into
    wireless-access-point mode.
       Visit http://www.netgear.com/support , put in your model number, and
    look for Documentation.  Get the User Manual.  Look for "Use the Router
    as a Wireless Access Point".
    • William10a's avatar
      William10a
      Master
      I agree that would give you wifi and wired access in the remote location and solve the double nat issue.
      So use the netgear router in access point mode.
      • 2pfspiff's avatar
        2pfspiff
        Guide
        Thanks for the reply.  Wasn't sure what the access point does.  Will have to read up on it.
