LadyLegend
Nov 10, 2018Aspirant
Double Nat R7000 and n450
I am computer literate, however, network illiterate. I'm going to explain my issue as best and simply as possible.
I have the following devices and the following attached to said devices:
- Nov 10, 2018
if the Netgear N450 modem/router is still acting as a router then the r7000 should be configured as an AP. Unless the N450 is configured as bridge only it is also a router so connecting the r7000 as a router causes the double nat. So either change the N450 to bridge or change the r7000 to AP.
michaelkenward
Nov 11, 2018Guru - Experienced User
LadyLegend wrote:
>Netgear N450 modem
Yes, but which N450? N450 is a speed designator, not a Netgear model number. It just tells us that you have a now slightly old device with yesterday's wifi technology.
CG3000Dv2? That's the only "modem", or Gateway, with that label.
