LadyLegend
Nov 10, 2018Aspirant
Double Nat R7000 and n450
I am computer literate, however, network illiterate. I'm going to explain my issue as best and simply as possible.
I have the following devices and the following attached to said devices:
- Nov 10, 2018
if the Netgear N450 modem/router is still acting as a router then the r7000 should be configured as an AP. Unless the N450 is configured as bridge only it is also a router so connecting the r7000 as a router causes the double nat. So either change the N450 to bridge or change the r7000 to AP.
michaelkenward
Nov 11, 2018Guru - Experienced User
LadyLegend wrote:
>Netgear N450 modem
Yes, but which N450? N450 is a speed designator, not a Netgear model number. It just tells us that you have a now slightly old device with yesterday's wifi technology.
CG3000Dv2? That's the only "modem", or Gateway, with that label.
LadyLegend
Nov 11, 2018Aspirant
michaelkenward wrote:
LadyLegend wrote:
>Netgear N450 modem
CG3000Dv2?
Yes. that is the correct model of modem I have. Sorry about that.
- michaelkenwardNov 11, 2018Guru - Experienced User
That is a router. So heed the words of myersw.
I see no built-in "modem only" mode for this device. So using the R7000 in AP mode may get rid of the "double NAT" issue.
Posting in the appropriate section might also yield better advice:
