LadyLegend
Nov 10, 2018Aspirant
Double Nat R7000 and n450
I am computer literate, however, network illiterate. I'm going to explain my issue as best and simply as possible.
I have the following devices and the following attached to said devices:
- Nov 10, 2018
if the Netgear N450 modem/router is still acting as a router then the r7000 should be configured as an AP. Unless the N450 is configured as bridge only it is also a router so connecting the r7000 as a router causes the double nat. So either change the N450 to bridge or change the r7000 to AP.
michaelkenward
Nov 11, 2018Guru - Experienced User
LadyLegend wrote:
>Netgear N450 modem
Yes, but which N450? N450 is a speed designator, not a Netgear model number. It just tells us that you have a now slightly old device with yesterday's wifi technology.
CG3000Dv2? That's the only "modem", or Gateway, with that label.
HiSpeed
Nov 11, 2018Guide
Hi,
It is possible to cascade 2 NAT routers but, to work properly, the first needs a DMZ to second, and a firewall off...
- myerswNov 11, 2018Master
HiSpeed wrote:
Hi,
What is needed is for the one to be an AP. That basicly sets fiirewall off, but only part of the puzzle. Also need to get the dhcp from the DMZ router and also point at it for DNS lookups. Easier to just set to AP mode and let the firmware handle things. Have done what you are suggesting, I think, on DD-WRT, but see no reason to muck around when there is a setting.
- michaelkenwardNov 11, 2018Guru - Experienced User
HiSpeed wrote:
Hi,
Yes, but why bother when there are easier options?
- HiSpeedNov 12, 2018Guide
In France, the (first) modem-router is generally provided by the ISP (named Box) because of VoIP and IPTV capabilities not existing into commercial modem-routers.
Often these Boxes can't be bridged, obliging a double NAT if a powerful commercial router is used for other reasons (better network control, better wifi, etc.)...
