rwxrwx
Aug 12, 2020Guide
Double NAT
To resolve a double NAT issue I toggled off the router portion of my combo router/modem unit. Now I can't access the modem to change settings using the IP address 192.168.0.1, 192.168.1.1 nor the web addresses such as routerlogin.com.
How do I access my combo when the only method by which to do is via wifi? I will add that my PC is hardwired via ethernet and not wifi and is what I use to access the unit.
try 192.168.100.1
That's the default address for the modem.
try 192.168.100.1
- rwxrwxGuide
Thank you! That worked!
I have one other concern though. Most of the settings that were there prior to me turning the router off are now gone. There a reason for that?
Not 100% but switching it over to modem only mode disables the router function. maybe its a component of modem only mode to reset the router back to defaults.
