Robwuk's avatar
Robwuk
Tutor
Mar 28, 2022
Downgrading firmware
Because of DNS issues in the latest revision, I am trying to downgrade my firmware from V1.4.2.84_1.3.42 to R7900P-V1.4.1.62_1.3.22.
I select the .chk file but after a few seconds of uploading it says connection reset and nothing else happens. What am I doing incorrectly?
Rob
  • Where on earth is Netgear in this debacle? This has been an issue for months. I still get "DNS_PROBE_FINISHED_NXDOMAIN".
    Now it is not only impacting webrowsing but I suspect another application that uses DNS.
    It is hard to believe that a company for whom this is core business has not fixed this yet.
    • FURRYe38's avatar
      So you'll need to downgrade to prior FW version or what worked for you.
    • Robwuk's avatar
      Robwuk
      Tutor
      I did downgrade to V1.4.2.84_1.3.42 with the help of netgear support. But I am now still getting the issue.
      • FURRYe38's avatar
        v.84 is the recent version of FW so you'll need to downgrade to something older then this version. Try v.62?
