Giselle479's avatar
Giselle479
dual band wifi router
I am looking to add my own router instead of the new Spectrum router they just installed.
I can't have a router that selects either 2.4 or 5ghz.  I need one where I can choose which device uses 2.4 and which device uses 5ghz.
My security cameras and Android Tab A 10 only seem to work on 2.4 ghz.
Our iPad works best on 5ghz.
I don't see which product will do this.  Most say they will switch automatically to strongest network.
Can someone please suggest the correct Netgear router product for my needs?
The Spectrum modem does not appear to have a name, but on the bottom it has about 8 lines of numbers.  Sorry, not tech smart
thanks,
  • plemans's avatar
    Jul 12, 2020
    The R6850 is a dual band router that doesn't have smart connect so the bands aren't connected with the same ssid unless you set them the same.
    so you have the option of using either band.
  • plemans's avatar
    Many of netgears single router solutions would work. You'd just disable smart connect if it has it. Smart connect is the single ssid (name) function that steers devices between bands.
    the mesh routers don't have the option of disabling smart connect.
    But you should try running it first with it enabled. Most devices won't have any issues.
    • Giselle479's avatar
      Giselle479
      I was
      I  was considering AC2000 ROUTER. It sounds like i could hook up old devices to 2.4 and newer devices to 5ghz.  Does that sound right?
      • plemans's avatar
        ac2000 is a speed. What model are you looking at?
        What issues were you having exactly with smart connect?
        What router is it?
        modem you're using?
        firmware on the router?
