TexanEsparza's avatar
TexanEsparza
Dynamic QoS grayed out?
I'm trying to prioritize certain applications through Qos and disabled AP mode and set up the Qos under advanced settings, but the Dynamic QoS button under the basic tab is still grayed out. Am I missing something or is there another way to prioritize applications?
  • What browser are you using? Try IE11, FF or Opera.
    Try a factory reset then set up QoS in router mode. QoS only works in router mode. Coming back from AP mode to router mode should be able to use QoS settings after getting back to router mode.
  • FURRYe38's avatar
