magyarflyer's avatar
magyarflyer
Follower
Jan 28, 2022
eax12 extender and nord vpn incompatibility
installed eax12 brand new out of the box
when trying to install Nord VPN the extender freezes the entire system and comes off line
last time i tried it scrambled the original att u verse router so i had to replace the unit froze the entire unit with a mirror dialogue but that is beyond my level of knowledge
  • plemans's avatar
    Nord VPn is 3rd party firmware or a program you install on a device.
    It either installs directly to a end use device like a tablet, pc, laptop.
    Or it installs 3rd party firmware to something like a router.
    Its not installable to ATT's router or to the EAX12.
  • michaelkenward's avatar
    michaelkenward
    While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge, especially when we aren't talking about a router.
    You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
    WiFi Range Extenders & Nighthawk Mesh - NETGEAR Communities
    Those things are very different from the standard Netgear routers covered in this section.
    In the meantime you could visit the support pages:
    Support | NETGEAR
    Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
    You may have done this already. I can't tell from your message.
    I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
