HemD's avatar
HemD
Edit .cfg file from R9000
Hello..
Is there any way to edit .cfg file (setup backup file) generated from R9000 WiFi router? If not is there a easy way to extract "Block site/Key word" list so that I can copy this to my new AX8 router?
Currently the R900 router is running version 1.0.5.40.
Thanks.
HemD
  • FURRYe38's avatar
    No. Config files are not cross model usable.
    • michaelkenward's avatar
      michaelkenward
      The only option that seems to work is to get all the key data in screen shots.
      Alt + Print Screen is your friend.
