Mixie57's avatar
Mixie57
Follower
Jan 23, 2021
Email router logs via Yahoo
Trying to set up email for router logs and when I press Send Log, the log reports “ email failed] (#AUTH005) Too many bad auth attempts.”. I understand Yahoo doesn’t trust it but how can I enable this for sending the logs through Yahoo?
  • michaelkenward's avatar
    michaelkenward
    Some SMTP servers are more picky than others. If Yahoo refuses you, try another free alternative. GMail worked the last time I looked.
    I use smtp-mail.outlook.com
    • shadowsports's avatar
      shadowsports
      Hero
      Yahoo and ymail are poor choices for email period.  I wouldn't even use them as a junk account.
      As michaelkenward mentioned, there are several other alternatives.  I have used both Gmail and Comcast successfully.
      To be successful, you need to confirm the following:
      -Relay must be supported
      -That you have the account configured properly (example) Gmail requires that you enable "allow connection by less secure apps".
      and
      -That you have configured the Router properly with the correct SMTP information, username, password, encryption and port.
      My Logs are mailed once a week, Sundays at 8AM.  Below it what you will see in the log when mail is properly configured.
      [email sent to: XXX.com] Sunday, Jan 24,2021 08:00:07
      [Log Cleared] Sunday, Jan 24,2021 08:00:07
